Results 1 to 19 of 19
  1. Video Restorer lordsmurf's Avatar
    Okay. Time to quit searching, and just ask.
    Any suggestions for a cheap DVD-ROM drive (local pickup item, not online only) that can read DVD-RAM discs ?
    canada
    (Liteon)LTD (XJ-HD) -165h / 166s
    carry the new DVD-MULTI logo which means:
    "DVD Multi Drive is capable of reading DVD-ROM, DVD-R, DVD-RW and DVD-RAM media"
  3. I'm fond of the Toshiba DVD-Rom.
    Dirt cheap, and easy to find hacked firmware for Speed-Unlock / Region-Free. Models for IDE or SCSI. No +R or +RW.
    SD-M1612
    http://sdd.toshiba.com/main.aspx?Path=/818200000007000000010000659800001516/8182000001...00659c000005b1
    SD-M1712
    http://sdd.toshiba.com/cda/main.aspx?Path=/818200000007000000010000659800001516/818200...00659c00001113
    I made a night trip to Fry's just now, and grabbed an LG that says "DVD-RAM" right on the box. Here's hoping it works.
    Thanks!
    Was $39.99 plus tax
  5. Just about every Hitachi dvd rom can read dvdram. These can be had used on ebay pretty cheap. Go for any others like Nec, Toshiba and ppl will actually bid above retail for it. The used hitachis will go for 10 dollars and less. You can buy a brand new rom but I don't see the point. You're just going to use it to read dvdram right?
  6. Is there ANY DVD-Rom that will read DVD+R / +RW?
  7. I also like a reader for DVD-RAM, just in case. I am planning to get a Pioneer 107D writer no matter what, and i read somewhere that it can read DVD-RAM? Is that correct?
    au7usa: I think most newer DVD-ROM will read both +R and +RW.
    Jan 2002
    I've had it for a while, so I don't remember the model number. But the Lite-On I bought at WalMart reads Ram discs.
  9. Originally Posted by au7usa
    ANY dvd-rom reads +R and +RW
  10. Specs for all but one DVD-Rom i've found only lists DVD-R / -RW, not +R / +RW.
    Can you give me an example? (not a writer)
  11. Looks like you are right au7usa, i looked at a few models at 2 norwegian computer web-shops, and many listed only -R and -RW, but it could be some of them still does read +R/+RW, need to look at the manufacturer websites to be sure. I found one, Plextor PX-116A/T3BPB, and another one (Teac) said +RW but not +R, i kinda doubt it would not read +R when it can read +RW, but ok... It was a Teac DV-516E anyway.
  12. So far this is the only DVD-Rom drive (not a writer) that can handle +R / +RW that i could find.
    http://h18000.www1.hp.com/products/quickspecs/11472_na/11472_na.HTML
    Looks like it doesn't do DVD-Ram.
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    dvd recorders? no.
  14. Video Restorer lordsmurf's Avatar
    Originally Posted by Baldrick
    dvd recorders? no.
    Closest I could find.
    It did come from a DVD recorder RAM disc.
    Mar 2003
    Thanks!
    Was $39.99 plus tax
    What's the model number of that drive? And did it work for reading DVD-RAM? If so, I gotta get it!
    Jul 2003
    Ontario, Canada
    dvd recorders? no.
    LG 4082B is a less than US$100 8x DVD Writer can read and write any formats at this juncture!
    Sam Ontario
  17. Video Restorer lordsmurf's Avatar
    LG GDR-8162B
    Lists DVD-RAM on the back as a "compatible format".
    It reads the discs, but not the files in Windows ME. I have to use ISO Buster to extract the UDF files.
  18. Originally Posted by thor300
    I also like a reader for DVD-RAM, just in case. I am planning to get a Pioneer 107D writer no matter what, and i read somewhere that it can read DVD-RAM? Is that correct?.
    Mine does, but at 2X and with a lot of problems at the edges of the media.
    Still a few bugs in the system...
  19. Thanx Chas, even if it only barely works with RAM thats ok for me, and i will buy it anyway
