burn 700mb at 8-speed or at 12-speed?
because am thinking of geting some CD-RW's and need to know how long it will take thanks 2 any1 that helps!
Results 1 to 9 of 9
AAAAAAAAAAaaaaaaaaaarrrrrrrgggggggggghhhhhhhhhhhhh hhhOriginally Posted by offthehookpain
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
Is it too much trouble to insert a disc , set your burn speed to 8x or 12x and burn it. It wouldn't be any different a time for a CD-r or a CD-RW.
Also consider yourself extremely lucky that makntraks has still got yellow cards. That was your 13th post and it could have been very unlucky. -
Originally Posted by andyp1
Hahahahahahahahahaha
Helping where I can...
700 / 8 = 87.5 secondsOriginally Posted by offthehookpain
700 / 12 = 58.3 seconds
Those times are approximate but within +/- 600 secs.
y do u knead 2 no how long it takes 2 burn a CD?
wgl w/ da burn G2G ttyl WBS plz. -
[/quote]
nothing like an estimite with a 90.1% margin of error!
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Northcat,
I think you have your numbers a little wrong. 87.5 seconds? C'mon, leadin takes that long.
At 12X, 8 miinutes +. At 8X, probably half again as long, like 12 minutes. 2XDVD, 30 minutes, 6 times the data, unless you are giving the disks away, go DVD and get 6 times the data in the same length of time.
Back in the good old days, my 2X-1X took 35 minutes to tell me the burn was no good, and that was with a SCSI drive
Cheers,
George -
gmatov -
I said give or take 600 seconds.Originally Posted by gmatov
I think my numbers are accurate...I have a HP 9100a series CD+RW burner...though to be perfectly honest since purchasing my DVD burner, the CD burner has been on the shelf...some 3-4 years now. So my numbers may be off. -
700Mb is a full 80Min CDR, so at 1X it would take 80Min, so at 8X it would take.............yup 10Mins.
We'll be right back after these messages from Binford!
How long does a camcorder last?
By Schtil in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st Oct 2011, 05:47 -
Is it supposed to take this long?
By blaqlion22 in forum Authoring (DVD)Replies: 1Last Post: 20th Jun 2009, 08:41 -
How long to accept it ?
By logandu62 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Apr 2009, 16:18 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08 -
Why does it take SOOOO long?
By someonesomewhere121 in forum Newbie / General discussionsReplies: 7Last Post: 25th Mar 2008, 11:20
