  1. I have 2 avi clips which id like to put on 1 dvdr.
    Lets say my 1st clip is 1hour, 2nd is 2hours.
    Calculated bitrate for 3hours of movie is 3253kbit.
    Do i need to split it, or should i encode each clip at this bitrate? Which would never fit of course. But splitting those in 1/3 and 2/3 would give me really low bitrates.
    Any help would be great.
    canada
    Encoding both files at that bitrate will give you the desired file size.
    Dec 2002
    My Swamp
    If you find after authoring , if you use menus etc , that it is slightly too large , you can use DVD Shrink just to squeeze it slightly to fit the DVD-R perfectly.
  4. tnx 4 fast replies.
    yeah...it actually does make sense.
    Tmpgenc author gives me this error all the time, never guessed it were the menu's.
