I'VE RIPPED A DVD WITH SMART RIPPER THEN SAVED THE VOB FILES, BUT WHEN I COME TO PUT THEM ONTO DVDR THERE'S A SHORT GAP BETWEEN EACH OF THEM, HOW CAN I GET THEM TO RUN SMOOTHLY... PLEASE REPLY, I'M DESPERATE
This is cut n pasted from another thread I answered:
Here are a few tips to help get your question(s) answered:
1. Title you post according to your question. "NEED HELP FAST!!!!" or "I'M FED UP" are not the same as "Trying to convert Xvid to SVCD" (for example).
2. Completely fill out your specs in your profile. People will be able to diagnose your problem when they have some reference. Instead of "Answer: Use Windows program X. Thread starter: I can't. I'm on a Mac.", you'll get "You can't use DVD-RW because that drive only accepts DVD+RW. Nothing else."
3. read, Read, READ the guides. There's tons of info, and most guides almost literally hold your hand through the processes.
BONUS TIP:
Don't type in ALL CAPS. It implies shouting and is very rude.
After reading the above, answer these questions:
1. How big is the original DVD? That is, will it fit on a DVDR?
2. Did you rip the disc to a VIDEO_TS folder, or individual VOBs/chapters?
3. What are you using to author? Or are you re-authoring?
4. What are you using to burn? Nero? DVDDecrypter? -
Please lose the caps too. You don't come across looking very bright if you type in all caps.
SoUnDz LiKe ThErE iS mOrE tHaN oNe DvD u R tRyInG tO pUt ToGeThEr. DoNt B dEsPeRaTe, JuSt HaVe SuM pAtIeNcE aNd B sUrE tO cHeCk ThE gUiDeZ tO yOuR lEfT
Yeah, and regular typing would be more polite
Even a fool can be wise, all he has to do is keep his mouth shut -
Please... can't we be a little more receptive to a n00bs plea for assistance????Originally Posted by teegee420
Ooops,
apologies... should be more helpful.... NOT 8)
makntraksIn the theater of the mind...
It's always good to know where the exits are...
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 09:51 -
confused , newbie (more like overwhelmed)
By fordman37167 in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2008, 23:44 -
Newbie confused. PC crashes/does wild when I attempt to record
By rob1974 in forum Capturing and VCRReplies: 3Last Post: 25th Aug 2007, 10:16
