wondering if its possible to hook up my VCR to my PC using my system (specs below). if so how can I go abouts connecting it and what software would I need to capture the VHS tapes onto PC so I can them convert them to DVD or VCD etc.. any help would be greatly appreciated.
ASUS A7N8X-X
Athlon 1800 XP
ATI Radeon 9800 PRO
80 GB Maxtor hardrive 7200rpm
512 MB DDR PC3200
LG 40x24x40x
Windows XP PRO
I'm almost positive if you do a search of the site, or just look under the capture in the how to section there are one or two guides that can point you in the right direction, next time do a little work, and then ask why you can't find specific info. Just a note, cause I b*tched, assuming the ATI Radeon 9800 PRO is a TV capturing card, after you get the correct cables to run audio and video from the VCR to the card, you just need to find a good piece of software and your almost there...vdub, virtual vcr...if not you need to get a decent capture card.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
