I have upgraded my ait card and ran into difficulty with the dvd decoder driver set. when i try to run the install it ask for the cd. I put the cd that came with my card and it gets to the point where it needs to use it and says that it doesnt recognize the cd. Maybe i should put something in there other than D: ?
Here is what I have:
OEM CD:
Soft Release: 100 + dvd
480-v01054-100
Installed/installing:
control-panel-8-00-040322a-014266c
mmc-8-1-0-0-dao-mdac
mmc-9-0-0-0
tv-capture-wdm-6-14-10-6238
wxp-w2k-catalyst-8-00-040322a-014266c
DVD DECODER BUNDLE - atiCDwiz-v2-1
This happens with the older ATI cards like mine(7500). It's ATI's way of getting you to buy the new DVD software. According to the download page you need an install cd with at least MMC 8.1 in order to install it for free. Screw 'em. I use Power DVD which is a better player anyway.
ati 8500dv resource problems
By jwdove in forum Capturing and VCRReplies: 1Last Post: 27th Sep 2009, 13:48 -
Upgrading M/B & CPU, no other existing hardware, likely problems ???
By blinky88 in forum ComputerReplies: 5Last Post: 15th Aug 2008, 16:02 -
Likely problems upgrading motherboard from sis650 to sis651 chipset
By blinky88 in forum Newbie / General discussionsReplies: 1Last Post: 11th Aug 2008, 15:34 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
