During the project wizard I click (DVD) PAL encoding for my .avi file. Then it makes the files. Then I use TMPGenc DVD Author. I got that part down, I even made a DVD before. It's just this time it's different, I'm converting an .avi file from an ogm. So I have the audio file and .avi file. I make that into the PAL encoding I was talking about. It makes a mpeg2 file. There are 2 files, audio and video. So when I use TmpGenc DVD Author what do I do to put them both in there to make a good DVD?
Forget that post. I just found the guide on how to do it. If I run into any more trouble I'll be sure to post.
TMPGEnc Authoring Works 5 Version & HD-PVR Question
By TBoneit in forum Authoring (Blu-ray)Replies: 25Last Post: 18th Nov 2015, 18:20 -
Question about tmpgenc authoring works
By lizzoqops in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2010, 23:55 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 11:00 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 08:32 -
Another DVD Re-authoring Question
By videopoo in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 03:40
