I have a long (90+ min) AVI I'm trying to convert over for KSVCD burning. It uses the mp42 codec, and I believe AC3 audio. I downloaded all the proper codecs and DivX Doctor to clean up the audio, and it now plays just fine in Quicktime.
However, I cannot get it to rencode for KSVCD (or any VCD encoding, for that matter). My first problem seemed to stem from the fact that the drive I was writing to had a space in the name, which caused ffmpegx to split a directory reference (sorry, I don't have the error message).
The next time I tried it, it created the mp2 file just fine, and the .img files appeared and then it just choked, giving me an error.
I was using the quick preset for KSVCD, and changed nothing, using QuickTime to encode. Has anyone worked with a similar file under similar circumstances and had it work?
Here's the error I get (this one was on a plain VCD):
Code:INFO: [yuvscaler] Couldn't read FRAME header: bad header magic! **ERROR: [yuvscaler] Couldn't read frame number 15615! INFO: [mpeg2enc] Guesstimated final muxed size = 90001667 Input #0, mov,mp4,m4a,3gp, from '/Volumes/VideoFreedom/earthfroze.mpg': Duration: 01:32:08.5, bitrate: 1043 kb/s Stream #0.0: Audio: mp2, 44100 Hz, stereo Stream #0.1: Video: MS-MPEG4v2 (MP42), 480x360, 29.97 fps Codec type mismatch for mapping #0.1 -> #0.0
Results 1 to 1 of 1
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
