I have a WinTV Go that captures an AVI with the audio in mono. I use VirtualDub to extract the audio and then Tmpgenc to put the video and audio back together in an MPG (helps a lot with A/V sync to do it that way, instead of just pulling audio straight from the AVI).
If I do an ordinary "Save WAV" in VirtualDub, it creates a stereo audio file with sound in the left channel and silence in the right. I have figured out that if I choose "Left" under Channels under Audio/Conversion, that it will create a mono file of just the left channel (the one with sound in it).
I can then use another tool to turn that mono file into stereo (with the sound in both channels). But I'm trying to figure out how to make VirtualDub do this in the same pass instead. I have looked at the audio filters, and they look promising. However, any filter I use winds up giving me an "unconnected input pins" error.
I'd appreciate either a solution to my specific problem or a point to some basic tutorials on how to use VirtualDub's audio filters.
Virtualdub got an audio filter named Input, and another named Output, those must be used, then drag with left mousebutton to draw the lines from input to your filter, from your filter to output, DEL key deletes a line and so on.
Virtualdub filters in avisynth-faster? How to use them?
By salidarius in forum EditingReplies: 10Last Post: 3rd Mar 2011, 21:13 -
Is there a way to use avisynth plugins/filters within Virtualdub?
By Milardo in forum EditingReplies: 5Last Post: 5th Jan 2011, 03:52 -
Could I get some advice on which VirtualDub filters to use?
By ryangarfield in forum RestorationReplies: 8Last Post: 1st Jan 2011, 00:26 -
import VirtualDub filters into Vegas?
By Srivas in forum EditingReplies: 8Last Post: 8th Oct 2008, 05:49 -
virtualdub filters
By demonwarrior in forum EditingReplies: 5Last Post: 9th Jun 2007, 05:27
