Having re-installed Nero, I have found that neither of my 2 disk drives are there, and i have none to choose from to select. Any ideas how i set this up?
Results 1 to 14 of 14
Either the file "CDROM.CFG" got lost;
http://www.nero.com/us/631940731607601.html
or
Your not logged on as Administrator:
http://www.nero.com/us/631940824944968.html
Are you on WinXP? -
Hover over " Computer details" for my PC specs.
I guess i had to download that file from the 1st link? I did so but it was already in my Nero folder, so it obviously wasn't missing, and I've checked that I'm logged in as an Administrator.
Any ideas? -
Did you reinstall because you had problems with Nero? Uninstalling problematic software usually leaves problematic residue. If you reinstall the software, the installer occasionally won't overwrite files (libraries) that are current (date)..........even if they are corrupted!
There's a "Nero Clean Tool" to completely remove all traces for a reinstall at:
http://www.nero.com/us/631940828445001.html
I too would like to know;
"What are your system specs? Is this a Mac or a PC?".
The truth is in the details! -
ASPI layer working? see tools link on left to update ASPI driverAny ideas?
Thanks for the replies guys- I've attempted to install the ASPI driver, but I think it was there anyway.
I had to re install windows so thats why Nero had to be re installed, but prior to this it recognised bothg drives, as it always has. -
You're using the version of Nero that came bundled with your drive(s)?
Can we have more info please.
What operating system?
What other burning software is on this machine?
What ASPI are you trying to install?
Is DMA enabled? -
teegee- Yep, I think it is the version that came pre installed.
auyusa: XP Home
I only have Pinnacle Studio 8 editing s/w installed that is simailar to Nero
Its the "Nero ASPIen" driver that I was advised to install, but I think it already was.
Not sure about the last one though
is DMA enabled?Read this site on how to enable DMA mode in XP http://www.cdrlabs.com/phpBB/viewtopic.php?t=7625Not sure about the last one though
Thanks for the link Budz- I followed the instructions but DMA was already enabled- i sisn't have to change anything.
I think I'll have a go at uninstalling it with the clean up tool to see if that solves it. -
Nero ASPIen is for Win98 / Me
DMA......yeah your probably right. I was on a roll. -
Nero is PC only. kind of gives away the OS dont you thinkOriginally Posted by handyguy
DVD Recorders
By Dragoan in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Mar 2010, 12:19 -
Nero can't recognize CD/DVD Recorders!
By Charmer in forum DVD & Blu-ray WritersReplies: 16Last Post: 15th Nov 2009, 05:54 -
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 12:27 -
Panasonic recorders
By jjis in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Sep 2007, 12:06 -
Unable to burn with multiple DVD recorders with Nero 7.9.6.0
By Burner127 in forum Authoring (DVD)Replies: 1Last Post: 7th Jun 2007, 00:47
