Hi guys,
Well to be honest i got a very old computer - pII, 400mhz, 15gb and 128 mb ram + I use a tv card to capture.
When i capture to avi and convert it to mpeg and burn, the quality aint that good and it takes too long for the process. However, i was just wondering if there was a simple programme what could just capture straight to mpeg with great quality and doesent need great computer specs to do so such as Pinnacle.
Thanks.
There are programs that would do just that. But it would not help much, the bigger problem is your computer. I am sure most folks here would agree that you should get a newer and much faster computer.
It's time to kick some butts, and presto ( if you know what I mean ) -
Yep you definately need to get a new computer if you want to do much with video. I have a 900Mhz cpu 40 gig hd and 384 mb ram and am barely squeaking by. Really i need a second hard drive just for capturing , more ram and a faster cpu... oh well mabe in the future!
If you want a good capture card that captures directly to mpeg format look into any ati all in wonder radeon that has a theater chip. I got an inexpensive (used) one on ebay for about 40 bucks.
I think everyone is going to say you either need a new computer or a serious upgrade to your exsisting one.
Good luck!Donadagohvi (Cherokee for "Until we meet again") -
I'm suprised that i'm not the only one using a PII 400Mhz for video.
vcd4ever. -
I didn't mind my celeron 366 (@433) when I used it. It topped out at about 640x480 with 16 bit color (on the O/S drive). Since I didn't have a DVD writer then, I made VCD/CVD exclusively. I'd let it sit overnight and encode.Originally Posted by vcd4ever
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
