I want to save on mastering and create a DVD that is opening with a B/W menu [can be PAL or NTSC] and gives you the choice between watching the movie in PAL or NTSC, whatever standard your TV is capable of. I'm using DVD Studio Pro and you cannnot do it there: you have to choose when you start a new project what it's going to be : PAL or NTSC.
My Q: can it be done ? like with a header trick similar to [s]VCD passing as a VCD [TMPgenc] ?
On a PAL TV NTSC movies are B/W, I guess the same happens the other way around, right ? For the player it makes no difference, but for the TV it does.
Results 1 to 10 of 10
It can be done but it isn't supported by the dvd standard.
Originally Posted by Baldrick
Thanks,
Zetti -
I've made one with TMPGEnc DVD Author ...but did not create a menu...I just wanted to see if it would accept both formats on one disc.
You may want to get it and experiment further. -
Originally Posted by handyguy
One double sided DVD disc ... each side single layer ... one side PAL and one side NTSC.
However last time I checked quality double sided DVD discs are well just not being made. Also they tend to be about the same price as using 2 separate single sided DVD discs.
You can buy DVD cases that hold 2 discs and still be the same size as a single DVD disc holding case.
That would be how I would do it.
- John "FulciLives" Coleman
*** EDIT ***
I wanted to add this ...
The problem with putting both PAL and NTSC on the same disc (well same side) is that you have to have a menu to select which you want to play but the menu has to be either PAL or NTSC format.
So if the menu is PAL it can't be seen on a NTSC DVD player and if you do the opposite and make the menu NTSC then how will PAL DVD players be able to see it?
It's just a bad idea all around."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Originally Posted by FulciLives
Like I stated, almost all players will play a NTSC and a PAL disk, for them it's just data.
However, on your PAL-TV a NTSC disk will be played back in Black and white and vice versa I guess. If you create a menu in black and white the standard you use is of no importance anymore - the player will play it and the TV will show it. Choose your appropraite system from the menu [PAL/NTSC] and there you go ! That's the idea !! -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
