IM trying to capture the movie from my sony handycam dcr-trv19 to my computer. So far ive used image mixer, and all ive gotton is piucture with no sound. cam some one please tell me how to do this? The thing is that the computer isnt reading the camcorder, even though i installed all drivers and windows xp reconized it and said it was ready to use.
Please help!![]()
Results 1 to 17 of 17
I'm afraid your problem is very common. Freakin' Sony has some very nice camcorders but the best computers able to actually recognize them are Sony Vaios unfortunately.
I am not familiar with Image mixer. But when you bought your camcorder, there should have been an editing software that should also capture your video. Have you tried that.
Otherwise, you can look on the left and use one of the free capture software.
I assume that you are capture with a firewire card (IEEE1394), which is in fact a copy of the bits from the camcorder to the PC.
Hec54, sonys work on all computers I have seen so far. -
I don't believe that's the least bit accurate (i.e. nothing to do with whether the PC is a Vaio). Rather, the problem, more likely than not, has something to do with that ImageMixer software.
I have a TRV22 and both of my PCs "recognized" my camcorder the very first time I connect it (via firewire) and I haven't experienced any anomalies in that regard ever since.
Take the subtle hint up there in the parentheses and you should have no problem capturing with your TRV19. -
Originally Posted by Sugar
Yea im doing a usb connection. I cant get this too work and its making me mad. cuz i bought a DIGITAL camera for this and its not woking. Mabye i could get more help. Such as a site for new drivers or somthing.
The likelihood of getting USB to work very well for your purposes is virtually nil and the ImageMixer software is pretty much garbage.
Hopefully, you have a spare PCI slot and a few extra bucks left to buy a firewire card and cable. Try the links below (cheap firewire card/cable/sw combos) or visit your local Circuit City, Best Buy, CompUSA, or similar retailer:
http://shop.store.yahoo.com/extremepcgear/fire13945pci.html
http://shop.store.yahoo.com/iwin2win/fi133xpopcia.html
http://www.jr.com/JRProductPage.process?RestartFlow=t&Merchant_Id=1&Section_Id=1&Produ...ed.ADP+1890600
http://www.buy.com/retail/product_jump.asp?sku=20360743&SearchEngine=ya&SearchTerm=203...ft&dcaid=17194 -
I have the same camera model! It captures just fine for me. But I use a firewire instead of the usb that came with the camera. So far I have success capturing with Premiere, Scenalizer, WinDV and Windows Movie Maker. My firewire port is on my soundblaster sound card. Most people would recommend a dedicated capture card like Canopus or Matrox but anything will do really.
Originally Posted by tag
Originally Posted by Sugar -
Originally Posted by hech54
Okay, I stand corrected. Regardless, the resolution here is to go with firewire (as opposed to buying a Vaio for the sole purpose of capturing via USB). -
The USB is supposed to be used to transfer pictures not audio. Do as Tag says, unless you have one already, go buy a firewire card.
Sony makes some great products, but they try to make every product proprietary. They want to make sure that you have to fill your house with Sony products before any of them will work.
Originally Posted by gooberguy
DaWulf -
gooberguy
(I ain't no expert) I tried to do a half hearted search on your cam, and didn't get much. I have a TRV 330 cam myself and would like to offer this information. Unless I am missing something the USB connection is for downloading photos from the memory stick. The IEEE 1394 (Firewire for Apple or I-Link for Sony) is for transfering the video to your PC (Any make or model that meets the requirments) If you dont have a IEEE1394 port on your PC you can get one fairly cheap just about anywhere. You can even get a combo USB/1394 card if your system is full or you so desire. You can even get cards bundled with some fair video software if you look around just a bit. Now if you are currently getting video thru USB but no sound maybe all you need is a wire for audio from the cam to PC? I have read about others using various USB devices for video, but I don't have any experience with this. I think that 1394 is the preferred method and it works for me.
I saw something about a capture card in your specs. I am not familar with all the possible configurations but even without a 1394 or USB connection you may be able to get video into your PC. Depending on the inputs on your capture card. Maybe using the RCA jacks or s-video. Mess around a little and get back to us with your results. GOOD LUCKIS IT SUPPOSED TO SMOKE LIKE THAT? -
it's not any software or pc problem
What i did was use the camera to rca plugs and put that into my capture card, The quility nots that great but it works for now... I looked in circuit city and the card w/ the wire is anout 60$.
EDIT: i probally should habe said this be4 but i have a sony caio
PCV-RX450 -
GOOBERGUY
Now that you can get video into your PC I bet you are going to face all kinds of challenges. Like editing and converting and so on and so on and... Any how for what it is worth I do recomend a fire wire card for cam to PC transfer. Take a little time and shop around is my advice. You can get fully loaded deals or ultra cheap deals either way find something that fits your needs or wants or budget. The thing about cam to PC via firewire is that it is pretty much a perfect transfer and is ready for the easiest editing. Which brings us to what your going to do to the video after you first get it into the PC. Editing. Whether it is just cutting out unwanted scenes from home movies to adding effects for feature movies it will need editing. Which brings us back to looking for a firewire card that has at least some kind of software bundled with it. It can be a long slow process learning this video thing. It takes time, patience, will and money! Read all you can on the matter and keep us posted on your progress. Good luckIS IT SUPPOSED TO SMOKE LIKE THAT?
Looking For Something Better Than a Sony Handycam DCR-DVD105
By PeripheralVisionaryX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Jun 2011, 13:11 -
Cable for New Sony HandyCam DCR-HC28
By HoosierGuy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 21st Feb 2011, 17:15 -
Sony Handycam DCR-HC53E -- help!
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jun 2010, 17:52 -
Sony DCR-PC108E Handycam
By ckbasak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 13th Jan 2010, 12:57 -
Sony Handycam - DCR-HC20E
By nzmikey in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 04:17
