  1. need your help friends
    my gf got a new TV yesterday. trying to help her programm TV to the cable remote. I check the user manual from the cable box remote for the TV Code.. my TV wasnt listed. I was wondering if anyone might know the answer to it.
    she has....
    - Apex 27" Flat Television
    - using iO Digital Cable (Cablevision) -- she has the Black box, with the Black remote. I am looking for the TV code for Apex, programming the cable box remote.
    thanks.....
    jlo
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    A guide with all the remote codes should have been provided by the cable company. If not you can call and get one. Your other option would be to do a search for the cable box model number and see if the manufacturer has any documentation on their website pertaining to remote codes.
  3. I did check with the guide from the cable company.. I even went to the website to do a search on it. I'll do a search on googles and see if I can come up with something... if not, guess I have to call them up. thanks
    jlo
