I have a progressive Divx avi file with a frame rate of 23.976. I want
to convert it to NTSC DVD. I've seen lots of discussion of how to
convert it properly with Tmpeg but I want to use Mainconcept
encoder to encode the avi since it's so much faster.
I'm not sure of the frame rate in 2 screens and whether I'm setting
it properly. In the details screen, do I set the frame rate to 29.97
since this is I want to encode the mpeg file's frame rate to?
Also, in the advanced MPEG setting screen under the Video Settings tab,
do I set the frame rate here to 23.97 so that the pulldown is set
to 3:2?
in the first one set it to progressive and 23.976
in the second one -- set it to 23.976 also and if you had selected dvd in "MPEG TYPE" , pulldown will automatically be selected ..
if you go back and change the mpeg type after - you will have to go back and reset all your settings"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Best avi/divx to dvd encoder
By deanofire in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2009, 16:16 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 04:08 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 16:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 20:06
