No Barnabas MPEGVCR dosen't knock that file WAY out of sync but MPEGVCR dosen't like format DVD stream it like Program stream how min time do I tell this Barnabas, but odd thing is why some people have luck with MPEGVCR vs VideoReDo and other way a round so you see it just one no game other try diff tools you should know Barnabas.
I have done (7) 4 hour clip and edit then down about 3:15 hour finsh by cut all junk out and still had use dvd shrink after and they where still in sycn after play on my Home DVD Player and my REALmagic Xcard.
A good DVD Author tool should NOT be reencode the clip but not all DVD Author tool are the same.
Results 31 to 33 of 33
SHS,
MANY users find mpegVCR will knock the sync out of a LONG Hauppauge 250 mpeg-2 capture, even when the "program stream" setting is used. If your setup does not have sync issues with mpegVCR, that's great, but lots of other people can't use mpegVCR on long Hauppauge PVR-250 captures, no matter what setting they use as they lose audio sync. This does not happen with the Nanocosmos editor when editing, but that editor leaves MUCH to be desired. -
The only I think of there not using the tool rigth that only thing I can think off hand.
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge HD PVR Sync and Lines Problems
By Mitterhouse in forum Capturing and VCRReplies: 3Last Post: 7th Jun 2011, 02:15 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
new pc and my hauppauge pvr 250
By heman28 in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2008, 08:33
