Hi, I am trying to backup a dvd and I am having some troubles. I am using dvdshrink to shrink the dvd and using nero to burn. I do not get errors using dvdshrink, but whenever I try to burn, I get a "burn failed, communication error". I am not sure what is going on, any suggestions? Thanks in advance.
Added: I have burned a few dvds before this with no troubles at all, is there a protection on this dvd or something?Also, my burner is a hp (came with the computer) and I use memorex dvd+r/rw to burn.
Results 1 to 9 of 9
JuPiTeR172
vcd_man40@hotmail.com -
check to see if your dvd burner is set to DMA mode. sometimes in XP the drive will change to PIO mode. check this link on how to set DMA mode in XP: http://www.cdrlabs.com/phpBB/viewtopic.php?t=7625
Try going to HP and see if they have a firmware update for your DVD Burner. I had a similar problem with my plextor drive and the firmware update took care of it.
Hi, it is me again!
I am getting this error once again, it was solved for a while, but now I am getting it again...i have the latest firmware for my burner, so that shouldn't be the problem.
I have tried these methods:
1) using dvdshrink 3.1 and burning with nero
2) using dvd decrypter to decrypt, then dvd shrink to shrink, and nero to burn
Both methods have failed, any other suggestions? Please any help would be appreciated, thank you!JuPiTeR172
Make sure you're DVD player is set up as Master and not Slave, put it on a separate channel and replace your cabling, also de-activate any program running before burning , antivirus, scanner software etc.
Sectors Error While Burning
By rckowal in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 08:19 -
Burning a DL dvdr problem
By efiste2 in forum DVD RippingReplies: 3Last Post: 16th Jul 2008, 15:06 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 20:29 -
DVD burning error! =(
By ll ReNeGaDe ll in forum Video ConversionReplies: 44Last Post: 21st Oct 2007, 18:33 -
Error at around 20% while burning
By the_rider in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2007, 20:11
