Ok, Iam puzzled. I have not did anything to my pc different with in the last week. Yet when I attempt to burn a dvd r+ it now takes more than twice as long than it did last night (from 15 mins to 1 hour. I have changed nothing over night. Someone else must have had this same problem. If so please help. A buddy of mine had this happen. He ended up reinstalling his whole OS but I dont think that is needed. Can anyone tell me why this might be happening? Thank you
Check and make sure DMA is enabled. I'd almost bet money that it's not. (If you're using Windows XP it may have disabled itself- that's happened to me a few times for no reason that I can find).
If you have trouble re-enabling it, uninstall the IDE channel and reboot.
(BTW- from 15 minutes to 1 hour is 4 times as long, not twice). -
Bobk, I looked in the Secondary IDE Channel properties box and Device 0 was set to "Transfer Mode: PIO only". I changed that to DMA if available. We'll see if that works. Primary IDE Channel was already set.
Ok, I tried that and no luck. Should I be looking else where to enable DMA besides in the Device Manager? I thought it could have been the media so I tried another brand that I know worked a few days ago. Still taking forever. Any more ideas?
Ok its fixed. I had to uninstall the Secondary IDE Channel to get it to set to UDMA. Now it works fine. Thanks
ffmpegX taking LONG time
By macgurl in forum ffmpegX general discussionReplies: 1Last Post: 23rd Apr 2011, 01:50 -
Editing video in virtualdub taking so long!
By admirer in forum Newbie / General discussionsReplies: 14Last Post: 8th Apr 2010, 14:43 -
MPG Files taking a long time to open.
By Ads79 in forum Software PlayingReplies: 8Last Post: 13th Nov 2009, 10:39 -
Settings Correct? Taking a Long Time/.avi to DVD
By 5Buffalo in forum ffmpegX general discussionReplies: 3Last Post: 24th Dec 2008, 15:29 -
Making DVD video taking very long time. For advice.
By seymoria in forum Authoring (DVD)Replies: 4Last Post: 11th Mar 2008, 03:59
