Is there a way to convert a dvd in pal system to ntsc system ?
marva200,
Please try to read guides and perform forum searches before you ask a question. It will save you time as you can normally get an answer right away!
Here's the section of guides (found at the left hand side of your screen) that is relevant to you:
https://www.videohelp.com/convert#4;41
Searching for "pal to ntsc" (with the quotation marks) on the forum yields some interesting results too:
https://www.videohelp.com/forum/viewtopic.php?t=219852&highlight=pal+ntsc - This post contains just about anything you would ever need to know.
https://www.videohelp.com/forum/viewtopic.php?t=220775&highlight=pal+ntsc - Apparently, IFOEdit will do this for you.
Best of luck with your project, and welcome to VideoHelp.
Cobra
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
