I'm not taking sides here, just wanted to offer my thoughts and advice.Originally Posted by Zippity
Unless masri needs further assistance, this will be my last post in this thread.
Over and out,
Cobra
Closed Thread
Results 31 to 53 of 53
Here are a few tips to help get your question(s) answered:
1. Title you post according to your question. "NEED HELP FAST!!!!" or "I'M FED UP" are not the same as "Trying to convert Xvid to SVCD" (for example).
2. Completely fill out your specs in your profile. People will be able to diagnose your problem when they have some reference. Instead of "Answer: Use Windows program X. Thread starter: I can't. I'm on a Mac.", you'll get "You can't use DVD-RW because that drive only accepts DVD+RW. Nothing else."
3. read, Read, READ the guides. There's tons of info, and most guides almost literally hold your hand through the processes.
Use the above tips in whatever order that you like. Some get best results as is, others with 3, 1, 2 or in any other combination. Oh, one other little tidbit:
*Have a little patience (a lot helps too)
American or UK English is good too !!!
Not "okey im hapy mad the dmm puter fd me dvd ups how can yo mke dl 2 a svcd wn lst tri tmgn noworky, ned sum hlp plz"
.... you can't possibly ******* read that kind of nonsense.
Those people get Will Hay's "Wanker" Award.
In fact, I normally hope those people DON'T get any help until they get spelling/grammar fundamentals down first.Want my help? Ask here! (not via PM!)
You forgot one other very important tip, supreme:
The people on this board are not being paid to be here. They are also searching for answers to make the process of duplicating their own discs easier. They are under no obligation to help anyone. Treating them as if they are will make them cranky."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
So now My CRIME is being new here
masri had 7 helpful replies to his post, then he pissed off some of the best guys on this forum by not listening. Even teegee, who is usually first in, won't help. It's a bit ironic that you are berating us when all your posts contain insults. Even Fulcilives has a better record than that (when he's taking his medication)"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Gramma or whoever.....
This is amazing. Try to read the paragraph below, then consider what it actually says. The brain is a wonderful thing isn't it?
Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht
oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist
and lsat ltteer be at the rghit pclae. The rset can be a total mses and you
can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not
raed ervey lteter by istlef, but the wrod as a wlohe and the biran fguiers
it out aynawy. . WOW!
Originally Posted by p_l
See, now that's what we call a typo. :P
I was going to go on with a long post about your attitude and how you are the one needing help and how we know what we are doing and all that...but then I realized that I don't care. (and I am probably the most sensitive caring person you'll find around here)
I think now would be a good time to implement net-literacy tests.
Speaking of which, the font on my window is incredibly small. How do I change the size of fonts on this site?"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
@Zippity:
Read my avatar. If you haven't got anything constructive to say about the topic at hand then **** off.
You are as bad as a threadjacker.
@Masri:
It may well be that the brand of RWs you bought does not play well with your burner. If this is the case, try a couple of different brands. You can normally find at least one brand that will be tops with your burner.
In the future try to be a bit more positive - The programs you are using do not suck - you suck at using them. That's OK - all you need to do is learn a few more of the basics and the rest will look after itself. Most people here are willing to help people prepared to help themselves, and by asking the same question 3 times and not doing what someone suggested, you are not doing yourself any favours.If in doubt, Google it.
I still do, because I want to feel victorious when I make him realise that he could have solved his problem days ago if he'd just followed our bloody advice!
Fed up with random Sony Vegas errors.
By TMC83 in forum EditingReplies: 2Last Post: 11th Aug 2011, 03:22 -
Help! Fed up of blue screen, physical memory dump problem.
By Varchasve in forum ComputerReplies: 10Last Post: 2nd Jul 2010, 09:38 -
Fed up with Cyberlink Powerdirector - Can you help me choose something else
By gayclarke in forum Authoring (DVD)Replies: 5Last Post: 9th Jun 2007, 22:09
