  1. I have a blank VHS tape that I want to record this one movie on... I want to know how to make the tape "not be able to record" after the movie... The movie is about an hour and a half, and the tape is a 4 hour tape, and I do not want anything recorded after the movie... (I watch kids sometimes, and they get a hold of everything!) Is there a way to prevent this as the commercial vhs do? I know that when you try to record over a commercial vhs, the vcr will eject it? Is there any way to do this on a blank vhs?
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    There should be a small tab on the left or right corner(I forget which side), if you break it off, then you will have a small square left. This will make the tape unrecordable.
  3. of course, to make it recordable again, just put a piece of tape over the square....just FYI
    Friends don't let friends use Windows!
    Elisha Cuthbert is so a total schorchcake!!
  4. Oh, the question was seriously ment? I thought it was another one of those "how do i convert mono to 8.4 surround" So what do i break off to make a DVD+RW unrecordable like a commercial DVD-ROM? Sorry, cant help it...
  5. Originally Posted by thor300
    The tray on your recorder.... Of course....
    Not bothered by small problems...
    Spend a night alone with a mosquito
    Sep 2003
    paintball field in CA
    (Please see profile for system specs)
