  1. Hi,
    I am trying to create a DVD with ac3 audio and optional subbing ( i already have the .sub file, but i don't want the subs to be permanent).
    I used TMPGEnc dvd author, and it supports ac3, but not subs. I tried DVDlab, but there seems that it can't support ac3 (not sure whether it can support subs cause i can't generate the subtitle stream in the program).
    Can someone suggest another way, or a program.
    Thanks.
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    DVD Lab supports ac3 - I use it all the time. (ver. 1.1)
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. sorry, i am using dvdlab pro beta 3. but, dvdlab pro should be able to support whatever that can be supported in dvdlab right?
  4. Originally Posted by ylkien
    yes, I author 100% in AC3 in DVD lab pro beta 3, what is the problem?
    There is a reason why God gave us one mouth and two ears!!!
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    I would think so, but I also think that if you're using beta releases, you should expect bugs.
    try a non-beta and see if it works...
    - housepig
    Housepig Records
    out now:
  6. What are you using to create the ac3 files? DVD-lab won't create ac3 files for you, you'd have to use something like ffmpeggui, BeSweet, or another program to create the ac3 audio file.
  7. Well, i don't know cause i converted the audio to ac3 using ac3machine. tmpge author can author the dvd without any problem....but when i try using dvdlabpro, an error comes out when i try to compile (something about the files not being compliant). When i compile without the audio, there isn't any error....
    The video is in m2v format.
    Another problem is that the subs don't come out. When i import the *.sub file, nothing comes out...i don't see any time or subbing in the window (like the dvd-lab tutorial in here).
