well, i have a boatload(over 700) of racing videos that i want to convert to mpeg to be able to play to on a dvd player... can i use tmpgenc plus v2.5(or another program)to convert a bunch at once to dvd spec resolution and fps? any help would be greatly appreciated
Results 1 to 13 of 13
I believe TMPGEnc can do batch functions. What kind of video format are they? You realize this will take quite a bit of time, even with a fast computer. And you need quite a bit of HD space. It really helps on this forum to fill out your computer information.
oh my computer is a 2.8ghz p4, 512mb of RAM... i still have about 40 gigs free left, but that wont be a problem because i'll convert a bunch, delete, and convert again- i have a 2nd 40gig hard drive i could use also. and the files are different formats; ranging from wmv's, to avi's, to a couple of .mov's(i have the plugin for quicktime support for tmpgenc plus), and the the type i hate- real video .rm\.ram's... are there any tools or plugins to convert real video formats? and heres a snapshot i took just so you get an idea:
EOVideo will convert .rm to a useable format, even directly to mpeg.
TMPGEnc will do exactly what you need in batch mode, though long and tedious. Like watching grass grow.
Mainconcept MPEG Encoder will do it faster, unless you want to muck about in tmpgenc's advanced settings.
It depends also on what quality you want the output to be.Cheers, Jim
My DVDLab Guides -
Originally Posted by reboot
DVD authoring requires 720x480 for NTSC.
If you plan on authoring them to (S)VCD on DVD, then we're opening up a new can of worms.Cheers, Jim
My DVDLab Guides -
You might want to try tmpegenc source creator found on pegasys websight. Has 1 month fully functional free trial. It's much easier to "set-up" and run than most other encoders and accepts a variety of inputs, but will not handle ac3 audio. It will still take a long time to encode, even on a fast computer. Hope this helps
TeeGee, "352x480 is an acceptable DVD resolution"...I wasn't going to get into HalfD1, however, you are correct, it would probably be a better resolution to use for all those multiple files.
Cheers, Jim
My DVDLab Guides -
Yep. Unless your source is at least 640x480 you might as well encode to 352x480. Full D1 will probably introduce a lot of blockiness.
Make Two MPEG2 Files Same Specs
By shagratt71 in forum Video ConversionReplies: 28Last Post: 20th Apr 2012, 06:31 -
Joboshare dvd copy produced a bunch of files I dont understand
By rocks911 in forum DVD RippingReplies: 1Last Post: 31st Aug 2011, 22:38 -
Muxing a bunch of separate video files into one
By FatalX in forum Video ConversionReplies: 6Last Post: 24th Dec 2009, 00:27 -
Want to change a bunch of mp3 files to smaller bitrate
By happydog500 in forum AudioReplies: 6Last Post: 11th Aug 2009, 13:08 -
converting bunch of images with sound to video
By dsikorsky in forum Video ConversionReplies: 0Last Post: 10th Aug 2009, 16:34
