got a good lot of divx files and other avi/mpeg. i was wondering what the best prog to use to convert them and put them on dvd
Results 1 to 30 of 37
ain't no black
Download a trial copy of TMPGEnc Encoder. It's a good place to start. Lots of guides on its use to the left. You will also need a authoring program. I use TMPGEnc DVD Author.
you use tmpgenc to make dvd compliant mpg1 or 2 files, then use tmpgenc dvdauthor to turn the converted mpgs into vobs, don't forget to change your audio from 44000 to 48000
member since 1843 -
Lower the bitrate. Also with TMPGEnc you should use a PCM WAV file as your audio source. TMPGEnc often has trouble re-encoding compressed audio. To make a wav file open your avi with Virtualdub, go to the audio menu and select "full processing mode", then go to the file menu and select "save wav".
I use TMPGEnc and TMPGEnc DVD Author also.
Have a look in the guides section as everything you want to know is contained in there. If you get stuck post back.If in doubt, Google it. -
WTF !13 hours
As your pc is
pull the other one it's got bells on...Celeron 3.5GHZ
Harddrive space: 1.20 TB
RAM Memory: 1024ddr
Celeron 3.5GHZ
Overclocking just a bit
1TB Harddrive http://www.jigsaw24.com/proddesc.asp?ITEM=X325AGA
who can lend me a couple of quid?
how long would it usually take most people on this to convert a divx file to dvd. the divx file i am trying to convert is about 1hr and a half long
ain't no black -
90min film on my rig (see specs above) takes about 1 hr 10 mins @ 1pass full d1 using mainconcept at default settings (6000 avg)
Yours should be faster (using same s/w - don't use TMPGEnc that much now) but TMPGEnc would be slower but not by that much (maybe 30mins on my sys) unless u got loads of filters + NR + 2pass setup!
<edit> has your file got VBR audio (load into vdub) and TMPGEnc is reporting a stupid size by any chance? -
I am using TMPGEnc, and you can find details of my PC on my profile. Converting an hour of DivX to DVD took my machine only a few hours, but I like to go for quality so I have higher motion search precision.
It's very hard to give encoding times because everyone's machine is different. Depending on how you set up the encoder, what your system is and how it is set up, what else you have running and so on, people can have vastly different encoding times.
However, your 3.5GHz Celeron should eat that task alive. How did you get it that fast without it burning up? I would love to know how, because I'm always looking for ways I can tweak my own machine.
Cobra -
BTW hows tings in Larne?
I'm a Dungannon man meself wouldn't ye know.
Larnes quite sunny today for a change. got burnt at the north west yesterday. my computer really isn't 3.5 mhz. its 2.8 mhz thought it would be funny to see how many suckers fell for it
ain't no black -
Great strategy there, bub. "Let's mislead the people that are trying to help me"
Then the joke's on you because you're not likely to get much more help when you pull shit like that.
look who is cross because they got fooled. lol. what difference does it make what spec my computer was. i was only asking if 13hrs was long to encode a divx file. loser
ain't no black -
No need to look up the bad words dictionary. You asked for the best way, and got lots of good answers for the easiest way (but not the best in my opinion). Then you are trying to have fun about "who fell for it", are you a redneck with a double barrell behind the pickup seat or what? Having fun scaring people from the city, setting up traps to see how many "city-nerds" will fall for it? I think your problem is not only video related, there are some pre-requisitions you fail badly, unless you DONT want help?
i'd have my setting like that for ages. it was hardly like i posted about it. some of you guys are really tight up
ain't no black -
joeyjoejnr,
I think you have picked the wrong people to:
You'll find that people here know their stuff, since video-related matters are PC-based and processing-intensive.Originally Posted by joeyjoejnr
That really was not the way to introduce yourself to a new community, and if you keep on like that then you will give yourself a bad name. I would suggest honesty from here on, and you'll find you will get on a lot better with people. Anyway, what you did wasn't so bad, it was just mildly insulting. Over with now, anyway.
If you still feel like a 3.5GHz Celeron (or at least trying for it) then why don't you check out the link in my signature? I have heard that Celerons don't overclock too well, but it's worth a shot.
Cobra -
alrite. i'm sorry. i stand corrected. thought it would have been funny,. it wasn't wound some people up
ain't no black -
Cool.
Over and out,
Cobra -
anywho. i used tmpgenc and it took about 3 hours (think so - i was doin a databases exam) the file was 5.5 GB and when i go to play it it doesn't have sound and media player says it is 6 hours long. what did i do wrong :'(
i used this guide.
http://www.dvd-guides.com/guides.php?category=othertodvd&name=tmpegencain't no black -
+ did you scan the file for bad frames (vdub-mp3-freeze)has your file got VBR audio (load into vdub std it will tell ya) and TMPGEnc is reporting a stupid size by any chance?
Since when has honesty ever gotten anyone anywhere? I bet there are loads of occasions where you havent been honest, even on these forums. Nobodys perfect!, although some think they areOriginally Posted by Cobra
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 04:23 -
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 01:41 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 17:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 00:41 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48
