What happens when you try to play on your computer?
Results 31 to 46 of 46
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Does it play on your computer?
You have to try things a few times. Just because it didn't play doesn't mean it won't play if you try again."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Hey Mats, if I had that video I'd just open NERO choose VCD and burn.Why author? Maybe I'm missing something.
/Mats -
Originally Posted by Beyonder
Nero creates a menu for the VCD, this is what pops up first. -
So do you know why my initial method didnt work??
But I can't understand why so many insist on using Nero for everything?!? There are better apps for almost anything it does. It's not that horrible to use different tools for different tasks, is it? The Swiss Army Knife approach is never the best.
/Mats -
What's on your TV screen is a nero generated menu.
Notice the "generated by NERO" text.
Depending on the options you selected in Nero, pressing play, or the number 1 on the remote will play the clip. IF the version of Nero you have happens to work correctly.
Older (5.0xxxx) versions of Nero worked well for VCD, but not anything else. Not sure about the "Ultra" version.
Your first attempt failed, because you attempted to use Nero. As mats has pointed out, Nero doesn't do much correctly.
VCDEasy would most likely be your best bet. Drag the mpg to VCDEasy, author, then burn.
If your stuck along the way, don't forget to RTFM. -
Originally Posted by mats.hogberg"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
I've burned lots of vcd's with Nero and it won't try to author them if the file is the correct format.
This is carried out (just as when encoding) to meet specifications of the target format, and can be done more (VCDEasy) or less (Nero) successfully.
/Mats -
mats,
So for the final time, i create the bin/cue with vcd easy.
Then i go into nero and burn the bin/cue onto a cd???
Is that correct??
was wondering would anyone like to tell me what the bin/cue is or what authoring does??
Does it matter what kind os cd it is? cd-r or rw etc etc -
If you take a look under WHAT IS top left and look up what constitutes a VCD, and compare that to the mpg file you feed into the authoring app, you get what authoring does.
/Mats -
is that your real hair by the way
Just open nero and press the F1 key - problem solved! -
a novice!?
By eleventhdr in forum Newbie / General discussionsReplies: 0Last Post: 19th Aug 2011, 22:55 -
WD TV Novice
By gazoopert in forum DVD RippingReplies: 1Last Post: 16th Aug 2009, 07:21 -
Novice Question: Burning DVDs
By nana01 in forum Authoring (DVD)Replies: 5Last Post: 24th Apr 2009, 02:45 -
Novice looking for help
By rogue22 in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 05:41 -
Novice problem with RMVB files
By mestismoridin in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 21:29
