Please be gentle with me im a beginner when it comes to burning cd's dvd's etc etc.
Have downloaded a mpeg (a episode of angel actually) and tried to burn it (using nero ultra) onto a cd-r.
Now i put the cd into my dvd player and it correctly came up saying vcd etc etc and it started playing but all i get is a black screen with a black box in the middle (which is tiny) which i assume is the mpeg trying to play and it says created by nero at the bottom.
Am i not correctly burning the mpeg??
Please help!!
Hi, you may or may not be talking about WAREZ.
Please read the rules and AUP before posting if you have
not already done so. They can be viewed by clicking [HERE]
Thanks,
Mod Offline
Results 1 to 30 of 46
sorry to disappoint you but you know you shouldn't ass ume!
I never said it was warez!
And i can assure you it isnt otherwise i wouldnt be on here!! -
Originally Posted by BeyonderSure you did. Warez includes illegally obtained movies/TV episodes also, not just illegal software.Originally Posted by Beyonder
Try pressing play on the remote. Perhaps Nero created a menu for your VCD.
RTFM
Nero has a help button for it's VCD burning and authoring. Check the options (in Nero) to see if it's creating a menu or not.
make sure you're burning the right format, is the file Mpeg-1 or Mpeg2, in which case you need to make an svcd. also check the list on this site to make sure your dvd player can play vcds.
Beyonder, it IS warez if you don't own the rights to the programme. unless you do (in which case you wouldn't be downloading copies of it) you're breaking the rules - plain and simple.
so what you are saying is that if you subscribe to a site that allows you to download movies etc etc for a price for example wannadoos music club then that is breaking the law too?!!!
Anyway to the last guy have tried to burn it to svcd but nero comes up with an error saying
mpeg-1 instead of mpeg-2
invalid video stream 29.97 frames/second
352 x 240 pixels -
Does this video play in Windows Media player?
Are you burning it as a Video disc? We need more info."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
RTFM !
yes plays absolutely fine in WMA and yes am trying to burn it as a video cd.
what other info do you need and i will provide. -
i would guess if you read your service contract closely you will find what you're trying to do is not allowed.
and just because you pay for something (kazaa gold, for instance) does not mean you're within the law when you download copyrighted material.
i already asked you to provide info from gspot. -
Once again I am not or have even downloaded anything which is warez!
Cant believe everyone is having a go at me, usually i'm the one who's telling people to pay for stuff instead of stealing them on the net!!
Oh well. -
Some people think that if you say the same thing over and over again then it's true.
why thank you, is that your real hair by the way, anyway dont want to get into a slanging match, believe what you want.
All i wanted was help not people to take the piss!! -
you can post the screen capture here, as long it's below 50KB.
just follow the on screen instructions when you reply. -
skip the warez talk. i often download tv-shows/episodes I miss from friends that has recorded it for me. it is a gray area of course. but it will be allowed to discuss. if you want to continue discuss warez rules do it in our feedback forum.
gspot doesn't support mpg. use avicodec or videotoolbox.
Looks like a perfectly OK NTSC VCD. Author with VCDEasy. Create bin/cue (with VCDEasy) and burn (with VCDEasy or Nero).
/Mats -
Hey Mats, if I had that video I'd just open NERO choose VCD and burn.Why author? Maybe I'm missing something.Originally Posted by mats.hogberg"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Just let you know if you would like to print out the VCD cover,
try this
http://www.idiotpublic.sucks.com -
but thats exactly what i did just burnt it with nero and it doesnt play on my dvd player!!
Well it recognises that its a vcd but all i get is a tiny black box in the middle of the screen!! -
Yes. Just uncheck the "Burn" checkbox. VCDEasy can burn it too, if your system and ASPI layer is set up correctly, but that might be a daunting task.So create the bin/cue with vcd easy
Huh? isobuster is used to read ISOs, not to author VCD, which is what VCDEasy does.(will isobuster do?)
Neither. You select "Write Image" or "Open..." from the file menu. That's the beauty - it lets Nero do what it's good at - writing stuff to disc (and nothing else).then burn with nero? Do i burn this as a vcd or dvd or svcd???
/Mats
a novice!?
By eleventhdr in forum Newbie / General discussionsReplies: 0Last Post: 19th Aug 2011, 23:55 -
WD TV Novice
By gazoopert in forum DVD RippingReplies: 1Last Post: 16th Aug 2009, 08:21 -
Novice Question: Burning DVDs
By nana01 in forum Authoring (DVD)Replies: 5Last Post: 24th Apr 2009, 03:45 -
Novice looking for help
By rogue22 in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 06:41 -
Novice problem with RMVB files
By mestismoridin in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 22:29
