I am having trouble with audio in DVD Shrink. I have authored an avi file using Ulead DVD movie factory 2, adding chapters and menu's. When I play back the conversion (within DVD Factory) the film is fine, all sound etc is excellent. But when I try to burn it to disc using DVD Shrink I loose the last 30mins of sound. The video is fine but no sound. All the settings in Shrink are default and the compression rate is auto. Even if I play it back in the preview window it has the sound loss. So it must be something to do with DVD Shrink. Any ideas?
what type of audio are you using? PCM, MPEG, AC3?
are you creating your soundtrack in dvd factory, or an external encoder? does the audio play all the way through in the authored dvd before you run it through shrink? -
I authored the file (both audio and video) in DMF2 and can play it back using DMF2 once it has been converted etc and it is fine. I can't burn using this programme as it won't fit on the DVD+r. In DVD shrink the audio is PCM i think (i'm at work and can't check yet).
then first thing i would do is try another transcoder. check in the tools section.
if you get problems with programs other than shrink, then it's a problem with movie factorys' output.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
copy You Tube to DVD,sound leave problems..
By gary153 in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2010, 08:33 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59
