Is it possible to burn multiple vcd format files on a dvd disc to play in stand alone dvd players and if so how??????![]()
Results 1 to 14 of 14
Drop them all in TMPGEnc DVD Author. That should take care of it for you. There are other ways of course, but TDA makes the process pretty easy.
Sorry to come in on this post. I tried that, but TDA warned about bad settings. Do I just ignore that? and will it play OK on a standalone player?Originally Posted by teegee420"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
This one
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
368x288 ? that isn't vcd or dvd compliant...you must reencode.
Thanks Baldrick, If I convert to standard VCD, will TDA accept it?
I thought it was knocking it back because it wasn't DVD."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Convert to DVD, 352x240 mpeg1 or mpeg2. Basicly same same as vcd, but you can choose bitrate and mpeg1(must be cbr and max 1.8mbit/s) or mpeg2(can be vbr and max 9.8mbit/s).
Cheers
I'd use MPEG-2 if I have the option. I've seen some real compression disasters with MPEG-1 VCDs.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Yes, so would I, but I have some VCD's lying around that I want on DVD, and I don't want to convert them if they will go onto a DVD without any problems.Originally Posted by Nilfennasion"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
you only have to convert them outside the vcd spec, like 368x288 video. you can mix both mpeg1 and mpeg2 on a dvd also as long you make new tracks/titlesets for each.Originally Posted by tweedledee
Hi,
Like Baldrick has said, as long as you put the video with different settings in different tracks, TMPGEnc DVD Author will take it. I have tried with clips with different resolution (i.e. 352x240, 352x480, 702x480, etc.) and different format (i.e. mpeg1, mpeg2), and just follow the rules to put each of them in different tracks, and TDA did take them all. Even if the audio is 44.1k, TMPGEnc DVD Author will convert to 48k. It does make life easy. Very nice tool.
Cheers,
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52
