  1. hi all...
    i really need your help cause i need to convert a DVD to VCD with the perfect method....i saw on the web a multiple way to convert DVD to VCD but i need your advice ..
    if it's possible i want to have the subtitles too ...
    so please if someone can help the soon as possible it will be appreciate it...
    thanks to all...
  2. There is no perfect method and the source material makes a large difference (eg. Anime vs. live action). For subtitles I would suggest either:
    http://www.flexion.org/video/DVDConv/DVD2AVI/index.html
    or if you're a newbie you might want to try Flask, DVDx or DVD2SVCD.
