Hi
i recently purchased svcd2dvd and i am v.pleased with this program. It does exactly as it says it will and i have created 2 flawless dvds with it. However since i installed this program my windows media player has refused to play MPG's properly. I get a lot of green and wat video i can see is squashed to the top and has lines through it.
I d/led media player 9 and installed this to see if it would fix but it hasnt.
Just hopeing someone out there knows how to fix this problem and whether any one else has experienced it?
Phil
sounds like svcd2dvd has replaced your MPEG2 codec on your system. try using one of the mpeg2 codecs in the tools section, could be a bit of trial and error to find one that likes both wmp and svcd2dvd.
SVCD2DVD does nothing with codecs and does nothing that may effect how WMP plays anything.....
you could try nero showtime comes with the nero 6 suiteOriginally Posted by PhilW1
realone player does mpeg, but i don't get on with it.....
i'd still try one of the mpeg codecs from the tools section, as mpeg2 codecs will handle mpeg1 as well.
Problem With Windows Media Player 11
By jonghyunchung in forum Newbie / General discussionsReplies: 8Last Post: 18th Oct 2008, 15:47 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Install Problem with SVCD2DVD 2.5.3500
By ebbtide123 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 28th Nov 2007, 12:46 -
Windows Media player problem
By Super Warrior in forum ComputerReplies: 3Last Post: 17th Nov 2007, 14:20 -
problem with Windows Media Player
By marlo in forum Newbie / General discussionsReplies: 4Last Post: 17th Nov 2007, 10:52
wat programs other than wmp would u recomend for playing mpegs?
