  1. When ever i encode a movie with Tmpgenc the sound is a few seconds off from the picture. How can i fix this.
    Dec 2002
    My Swamp
    A lot of times problems like this can be solved by extracting the audio from the AVI and saving it as a .wav . Then use the .wav as you audio source in TMPGenc.
  3. What do i use to extract the audio for the file.
  4. yep thats exactly what i do, but you might have a prob when loading into vdub as sometimes the avi needs to be decompressed
    http://mpegencoding.proboards20.com/index.cgi#general
    2 files here, the decompresser and the word doc to explain it all
