  1. In the tool user comments for VideoStudio8, Petetmt59 wrote:
    ... it can encode 100% compliant AC-3 (Dolby Digital) 2.0 audio. It didn't do this originally, but entering the lines:
    PlayAC3=1
    DecodeAC3=1
    UleadAC3Encode=1
    ADVANCE=1
    into, well, basically any section of the *.ini files that come with the program, especially the [MPEGVIO] and [VIODriver] sections of UVS.ini and DVDMF.ini . this will enable advanced settings in the SE version under the MPEG-2 template options
    Has anyone else been able to confirm this method to get VideoStudio8 to work with AC-3 audio (without having to do the whole demuxing, converting, remuxing thing)?
    Nov 2006
    Singapore
    has ANYONE any solution to get ac3 into videostudio SE
    thank you
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Upgrade to v10
    http://www.kiva.org/about
