I burned a DVD using Ulead video Editor for the recompressor to MPEG2 and Ulead DVD MovieFactory 2 for the burning , on the pc it looked ok , but on the TV the edges were off the screen ?!? , i did a 16:9 , 720x480 ,
can anyone tell me what did i miss?
Overscan on tv is what u missed.
huh? , can you explain it a bit more (started DVD work not too long ago) , i tryed a DVD with same size and format and all , and it worked fine , but myne - the edges are off the screen
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
