How do you have QT 6 Pro available for all users? I tried registering again (with other users) and no go.
What did it say when you tried to register it while logged in under a different name?
I ended up just copying all the QT preferences in User>Library>Preferences (4 total) to the other users and Pro was enabled.
Isn't there a global prefs section? /Library/Preferences should work, no? Try putting it there.
If it isn't broken, take it apart and find out why.
blog: deadsierra -
I dunno if that works. I installed QT into the Applications folder, so every user could use it and registered as Pro. When I logged in as root I no longer had the Pro version.Originally Posted by deadsierra
All I did was use my same registration information in QT as root and it registered it there too.
Quicktime Pro 7
By JBird in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 11:15 -
Need Converter like Quicktime Pro
By seskanda in forum Video ConversionReplies: 9Last Post: 31st Jan 2010, 22:34 -
Some questions about QuickTime Pro
By VidHunter in forum MacReplies: 1Last Post: 8th Jan 2009, 13:04 -
EditStudio pro users
By Illusionist in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2008, 18:52 -
Need input from SONY VEGAS 8 PLATINUM users -- not pro
By jg0001 in forum EditingReplies: 0Last Post: 23rd Nov 2007, 12:10
