    Mar 2003
    croatia
    I made a divix movie with Xmpeg (direct stream audio copy - ac3), now I have two files .avi and .ac3. How to play this movie (both files together) or how to multiplex them in one .avi file??
    thanx
    Indy
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    You should be able to mux them together with AVI MUX GUI.
  3. How bout Media Player Classic for Playback.
    Mar 2003
    croatia
    done it with AVI-Mux GUI but can't hear any sound when playing!?
    Indy
  5. If your trying to play with Window Media Player you'll need to have a AC3 decoder filter, in addition to "AC3 from AVI XFORM" filter.
    Any DVD player software should be able to decode AC3, but to allow AC3 audio stream in AVI you have to install "AC3 from AVI XFORM". The filter is named "MPGAudio.ax" and can be found with a simple Google search.
    An alternative is the Gabest filter "AVI <-> AC3/DTS", found at:
    http://sourceforge.net/project/showfiles.php?group_id=82303&package_id=84797
    Media Player Classic (Gabest) has this stuff built in!
  6. Member teegee420's Avatar
    Dec 2003
    Southern California
    Media Player Classic is an excellent suggestion. You'll need an ac3 filter at some point if you use another player though.
    Mar 2003
    croatia
    it works now with media player classic, thanx....
    Indy
