I'm using Nero's nerovision express 2 to make avi converted and burned to DVD video movies. It works perfectly.
Now is the question, how do i put a subtitle file (.sub or .srt) into the burning process?
I want the subtitles to work on my complete burned DVD movie....
How? You obtain a authoring program that allows you to import substreams. Or, you could permanently encode them into the video, in which case you would just import the new video.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
You need to learn how to use VirtualDub or better yet AviSynth
Then you need a real MPEG-2 encoder like Cinema Craft Encoder Basic or TMPGEnc Plus
- John "FulciLives" Coleman
P.S.
The best way to hard encode subs to the video is with AviSynth scripting."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
Bluray to dvd ( include menus )
By pcb in forum Blu-ray RippingReplies: 7Last Post: 26th Apr 2010, 21:35 -
Video quality worse after burning .srt subtitle into .avi file
By twenty in forum Newbie / General discussionsReplies: 2Last Post: 10th Feb 2010, 08:51 -
Which video file format can include metadata, like keywords, description et
By dumbletore in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2009, 00:10 -
How to include a 320x256 size video in a DVD
By dvdnewb2 in forum EditingReplies: 3Last Post: 18th Aug 2008, 09:19 -
How do I include wmv to a dvd with mpeg2?
By Jensen in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2008, 21:50
