i want to know about AVI format compressions i got ulead and it can convert it to avi but i dont know what compression to pick.. i have several options DV video encoder- type 1, dv video encoder - type 2, mjpeg compressor, cinepak codec by radius, intel indeo video r 3.2, intel indeo r video r 4.5, intel iyuv codec, microsoft video 1 , indeo video 5.10, divx pro(tm) 5.11 codec, microsft windows media video 9. microsoft mpeg4 vki codec v 1, microsoft mpeg4 vki codec v 2, microsoft mpeg4 vki codec v 3, microsoft mpeg4 vki codec v 4 .
which one compresses it to the smallest size file?
i had to install some other codecs to play certain videos but what formats are playable on someone elses computer who hasnt installed any codecs they just have windows media without any installed codec ohter than what was included when downloaded from microsoft.. say i email the compressed file to someone with windows media player which compressed codec format out of the list above will play on someone elses computer that might not have all the extra codecs installed..
thanks
Results 1 to 15 of 15
Smallest file size, and mutually playability are exclusive.
Smallest file size is probably DivX, at a very low bitrate (correct me if I'm wrong here). Mutual playability is probably WMP9 or MSV1, and possibly the 4 msmpeg ones.Cheers, Jim
My DVDLab Guides -
I would output as DV AVI, then re-encode to WMV using Windows Media Encoder. I'm pretty sure Ulead doesn't allow you to output as WMV. Most people should be able to play that without installing anything.
Originally Posted by reboot
<output as DV AVI?>
do you mean DV video encoder, if you do, do mean type one or tpe two? -
Type two should be fine. I believe it's the most compatible for video apps. Just so you know, file sizes for DV are in the neighborhood of 13gb per hour of video. That's not really a problem because you'll be converting to a more compressed format. WMV in this case, that is if you follow our suggestion. You always want to have the highest quality source file that you can manage. DV is about as good as it gets.
Teegee420, why output as DV and then re-encode. Double encoding is going to reduce quality, at least a little.
Isn't "microsft windows media video 9" simply another name for one of the many variants of wmv?
Output direct to that would be my suggestion. -
Originally Posted by bugster
The closest thing is going to be WMV, and that's not transportable to mac.Cheers, Jim
My DVDLab Guides
Best compression, smallest size, highest quality?
By Sullah in forum Video ConversionReplies: 17Last Post: 12th Nov 2022, 10:48 -
Converting DVD's to best quality smallest size video file
By Thunderblaze in forum DVD RippingReplies: 1Last Post: 31st Dec 2011, 04:07 -
By Reckitt in forum Video ConversionReplies: 2Last Post: 27th Feb 2011, 08:39 -
How Can I Convert Video to MKV with a smallest Size?
By MKV Only in forum Video ConversionReplies: 8Last Post: 24th Mar 2010, 16:17 -
Quick compression size question.
By capman21 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2008, 20:35
