Hello everyone. I am trying to use DVD Decrypter so that I can rip out the credits of a movie (which is the last chapter in IFO mode). I uncheck chapter 19 and then run the process where I end up with DVD navigation file and a set of 8 VOB files. There are also two text files for chapter information and stream information. Basically, I am trying to get the file into an ISO file so that I can open it in Dvd Shrink and transcode it. The credits are taking up ~400 meg that I could really use. I tried to use ImgTool but I get the Error: video_ts.ifo can't be found. Any help would be appreciated. Thanks.
My unexpert opinion is that you need to CREATE a new VIDEO_TS.ifo file . Use DVD Toolbox or similar.
Hope it works -
You screw up the DVD structure - you have to correct the navigation files.
I would rip the disc again in FILE mode and use TitleSet Blanker or VOB Blanker.
Or just download CloneDVD 2 (14 days trial)You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
Using DVD Decrypter should I use .ISO or .IFO file !
By augustya in forum DVD RippingReplies: 21Last Post: 29th Mar 2012, 11:44 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 12:21 -
DVDDecrypter IFO Mode - How do I know what cells belong to an angle?
By Gatlinator in forum DVD RippingReplies: 6Last Post: 26th Dec 2010, 04:03 -
timeline problems - IFO mode only (VOBSET works)
By charliem in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Aug 2009, 05:32 -
DVD Decrypter IFO I
By drstew in forum DVD RippingReplies: 6Last Post: 2nd Dec 2007, 23:42
