hi people:
someone can indicate me a tutorial for rip JUST THE EXTRAS BUT KEEPING MENU? where i find this information?
i want to backup a CRANBERRIES SHOW DVD without compression to 2 DVD-R'S
DVD-R 1: MENU + MAIN MOVIE -> i can do with DVD SHRINK + DVD X COPY
DVD-R 2: MENU + EXTRAS -> DVD X COPY don1t allow to skip main movie
thanks in advance for that reply me
what is with you people why do you seem to have the need on posting things more than once?
How Big A Boy Are Ya? -
You just want to remove the main feature? Well delete those vobs. There you're done. Look on the dvd and find the titleset with the highest numbered vobs, like VTS_01_4.VOB and VTS_01_5.VOB. This is usually the main feature. Load them up in dvd2avi and preview them to be sure. Just delete all these vobs except the VTS_XX_0.VOB. So if your movie is in VTS_01_1.VOB through VTS_01_5.VOB, then delete all the vobs in this titleset except VTS_01_0.VOB. That's where the menu's are almost always contained.
This works unless any of the extras are contained in the same titleset as the movie. That's rare but I guess a concert DVD could be an exception. Just check in dvd2avi.
If you select the main movie from the menu while playing the disk then the DVD will stop altogether. If you want to prevent this then open the IFO for the movie, go through each PGC and highlight it and hit delete playback. Now when you select Main Movie from the menu it will just go black for a second and return to the main menu. Another option would be to purchase MenuEdit and delete the button for the main feature altogether so its not possible to select it.
Removing the main feature should literally take about 2 seconds. -
thanks for their answers guys, now this job seems much more simple to me that i was thinking before. great help
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 08:36 -
Add subtitle, keep menu/extras
By canaQ in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 05:36 -
Stripping DVD extras, while retaining menu
By Hurre in forum DVD RippingReplies: 3Last Post: 19th Feb 2008, 10:14 -
Need a Guide/Tutorial for Sonic Scenarist and Menu creation with Photoshop
By src2206 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2007, 04:04 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 09:27
