Anyone able to tell me if has NEC ND1300 dual layer firmware available ?
According to Philips it will not be possible to upgrade existing 8x DVD recorders to DL layer recorders, contrary to what some rumours are saying.
In theory the laser power of an 8x drive is strong enough to handle DL but the problem is, is that the OPU (Optical Pickup Unit) of the drive is often not good enough.
This will lead to quality problems.
However, some drives with good OPUs could, in theory, be upgraded although they’d have to be handpicked.You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
Will ther, or is ther, a list of dvd burners that could be upgraded to DL with firmware?
So far, just 3 manufacturers...Originally Posted by Neomorpheus
LiteOn/Sony
812S/U18A: very likely (>90% probability)**
451S/851S: iffy (~30% probability?) (i.e., not impossible, but don't count on it)
NEC
2100A/2500A: very likely (>90% probability)**
BenQ
822: BenQ will officially release a DL upgrade on Sept. 30
**Although both of these have been confirmed, there is still worry because
1) the tests were done only on experimental firmwares; things could change between the test firmware & the actual retail
2) results will likely vary from drive to drive, as DL drives have the same hardware as SL drives, but are built with tighter tolerances, so SL drives that don't fit into those tolerances will likely have problems and not produce very good burns -
The SONY DL drive f/w will have a media compatibility table excluding any and all dual layer DVDR disks known to mankind.
I also felt like being an ass (since I am a SONY recorder owner).
The more I learn, the more I come to realize how little it is I know. -
don't recall where i read it, but the failure rate for flashing SL drives to DL burners was a whoppy 70%. did anyone else read this. wish i could recall the source1) the tests were done only on experimental firmwares; things could change between the test firmware & the actual retail
might it have been Philips
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
