I bought a Winfast 2000xp expert only to find out that I have a VIA chipset and cant capture in sync.
My question is if I buy the usb version of the card will I be able to capture in sync? because I think that VIA Latency only affects the PCI bus.
So has anyone done this with a VIA chipset?
Thanks in advance.
by the way my motherboard is PM266A
Why do you think it's the VIA Latency causing probs?
My mobo has via chipset and I get no sync probs,
your pc specs seem more than enough to be able to capture in sync - apart from only having 1 40Gb HD that is. -
I just assumed after trying everything else I dont know what else it would be.
Could be lots of reasons but my guess is its because your caping to a relatively samll hd that is also running the OS / swap file / anti virus + god knows what else.
I can cap at full d1 mpeg 2 on a via mobo and cap the sound via the on brd sound chip to an old crappy 10GB 5200rpm HD no probs (not used for anything else + gets a format when finished)
other reasons here--> https://www.videohelp.com/forum/viewtopic.php?t=166660 -
Depends on the chipset and the board.
I had to retire my dual processor P3 800 MHz running Apollo Pro 133 on Tyan Tiger because of this latency problem. Was running AIW card with the system and MMC just stop capping randomly under one minute.
The same chipset on CU4V ASUS board and single processor is OK with AIW.
Experiences may vary depending on chipset and boards.
A Good USB Capture Device?
By hech54 in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2007, 03:23 -
USB device capture
By ramin in forum Capturing and VCRReplies: 1Last Post: 15th Nov 2007, 15:48 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
capture device: usb or pci?
By danica in forum Capturing and VCRReplies: 2Last Post: 5th Sep 2007, 13:04 -
USB Capture Device
By gruberted in forum Capturing and VCRReplies: 13Last Post: 11th Jul 2007, 14:56
