Hi,
I'm trying to crop a video that I am converting from .VOB to mpeg. This is to get rid of the black bars top and bottom from the widescreen film. I use ffmpeg, and put 35 in the first two boxes in the crop options, but this does not seem to do anything. Do I need to reduce the output size by the relative dimensions, or what? By the way, as I need a CBR output, and so then need to re-encode in mpeg2enc, will this reduce the overall quality, even though I will encode at a high bitrate to start, and a much lower one for the final file (it's for a PDA).
Thanks for any help,
David
EDIT: OK, I've now read Wiseman's manual, and it seems like the cropping is not supported for mpeg1 at all (which is OK as I would have had to re-encode to CBR anyhow). Is this the case? If so, which format do you recommend I encode into in the first step so that I get the best final result? (please bear in mind that I don't have QT pro)
Use a value divisible by 2.Originally Posted by iMacfan
Why you don't immediately use mpeg2enc then, it already has a "Letterbox" option to crop.Originally Posted by iMacfan
No, that manual is for an extremely old version. The manual is here:Originally Posted by iMacfan
http://homepage.mac.com/major4
I need help with cropping!
By UnD3R0aTh in forum DVD RippingReplies: 23Last Post: 23rd Mar 2010, 02:33 -
Cropping...
By bsuska in forum Video ConversionReplies: 40Last Post: 15th Jul 2009, 16:27 -
cropping
By mwh99 in forum EditingReplies: 2Last Post: 7th Nov 2008, 13:25 -
Cropping DV
By bsuska in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 11:31 -
cropping
By exekutive in forum ffmpegX general discussionReplies: 5Last Post: 25th Aug 2007, 01:02
