  1. I have a divx file:
    Name.........: name withheld
    Filesize.....: 695 MB (or 712,673 KB or 729,777,196 bytes)
    Runtime......: 01:31:44 (131,974 fr)
    Video Codec..: DivX 5.0
    Video Bitrate: 926 kb/s
    Audio Codec..: 0x0055(MP3) ID'd as MPEG-1 Layer 3
    Audio Bitrate: 128 kb/s (64/ch, stereo) CBR
    Frame Size...: 656x368 (1.78:1) [=41:23]
    the sound was very low, so i loaded into Goldwave and modified/raised the volume of the file. Once that was completed i loaded the divx file in the video and the modified audio file in the audio.
    after it was finished i went back and ran the video to conform it was all good and there was huge green blob filling the screen and many more foul ups in the video. It was totally worthless.... So i went thru the whole process again thinking i made a mistake somewhere and the second run came out the same. any ideas?
  2. Yes. You've downloaded a shit quality movie from somewhere. Bin the shit quality movie and either use a decent P2P service or buy the DVD.
    Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
  3. Member teegee420's Avatar
    Dec 2003
    Southern California
    That's probably the best advice you can get. Garbage in = garbage out.
    San Antonio, TX
    A Runtime of 01:31:44 at a Video Bitrate of 926 kb/s.
    haha..
    Anything below 1500 kb/s is crap even for a vcd.
    IF YOU CAN READ THIS THEN YOU THEN YOUR EYES ARE DAMN GOOD! PLEASE, LET ME KNOW, BECAUSE I AM IMPRESTTED WITH YOUR GREAT VISION. LOL. BY THE WAY PEOPLE SUCK. EVERYONE SUCKS.
  5. Originally Posted by BlueWolf2005
    a vcd is 1150 so raising the bit rate to 1500 means it isn't even a vcd. Also bear in mind this is a divx file NOT mpg1 compression, IIRC its supposed to work with lower bitrates.
    People do suck though.
  6. i went ahead and burned it onto cdr for now....... i have it setup so i can watch it on the big boob tube if i really want to....... just like using dvd's more.........
    anyhow, after looking at that bitrate i am sure that is definatly the situation.... thanx....
    oh ya i looked for better copy on net and couldnt find one hehehehehe.
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I like it
    If in doubt, Google it.
