When i started encoding for about 5 or 10 minutes and after this time i
abort encoding, the files in the ouput directory are automaticly removed.
Wondering if there is a way to prevent this.
The reason why i abort encoding after 5 or 10 minutes is that i want to see
the result of what it has encoded.
You need to select a source range to encode your small 'test'
In TMPGEnc select: >Setting > Source Range
Then select a <start frame> marker and an <end frame> marker.
Set them pretty close together. (about 20 secs playback time should be long enough to get a good idea of the quality and won't take long to encode.)
When you encode only the footage between these two markers will be encoded.
Hope this helps. -
I've only seen this happen when I stop a two pass encode before the second pass begins. There aren't any frames to view until the second pass starts.
Need another program that removes subtitles from mkv
By s-toon in forum SubtitleReplies: 2Last Post: 26th Aug 2011, 17:13 -
PS3 needs full firmware update to play new BD but removes Linux. Options?
By gll99 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 18th Jan 2011, 01:39 -
Is There a Free Program that Removes Hiss and Pops from WAV files?
By cplevel42 in forum AudioReplies: 10Last Post: 24th Nov 2009, 13:28 -
AnyDVD HD 6.4.0.0 removes BD+ protection
By judgmentday in forum Blu-ray RippingReplies: 1Last Post: 20th Mar 2008, 08:19 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 10:58
