I have a large mpg file and i want to know if its possible to burn into a dvd format and if so how.
Results 1 to 10 of 10
nope, MPG files have some kinda ultra protection that we've been trying for almost a decade to get past. its a real bitch.. but we're gonna keep trying..
If you don't mind simple menus, TMPGEnc DVD Author is very easy to use and should work.
nope
Originally Posted by jeex
Quality
i found a way to break the protection jeexs was referring to. and for only fifty bucks, i'll let you use it
member since 1843 -
Stop pullin this poor noobs leg, guys!
DVD video is mpg, but there are certain requiremets to meet if it's to be used for DVD. Take a look under What Is, and check your mpg as fmctm1sw suggests.
/Mats -
1. Learn to search.Originally Posted by len111
2. Learn to read.
4. Read the CONVERT section over to your left to see whether you need to convert your file.
4. Read the AUTHOR section over to your left.
5. Convert if necessary.
6. Author.
7. Burn.
8. Watch it.
as jeex pointed out, if you're lucky there will be a way to do what you want to do by the time you complete the steps above.If in doubt, Google it.
Help to convert MPG to an Xbox 360 Format?
By lovelylisa in forum Video ConversionReplies: 7Last Post: 13th Jan 2012, 03:23 -
Is MPG the best format for saving DVD recordings?
By sldvd in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2010, 07:11 -
Looking to convert scr files (screensaver slideshows) to avi or mpg format
By wiltonp in forum Video ConversionReplies: 1Last Post: 23rd Jun 2008, 18:28 -
How To convert .flv videos to mpg format
By rbtechno in forum Video ConversionReplies: 1Last Post: 17th Nov 2007, 05:15 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
I was able to stumble across a little known program called
