Hi. I found out that my AVI video has twitchy playback. Could this be a codec problem or is the original video supposed to be like this? I'm not sure because I forgot who made the video. Anyway, the video is fine most of the time. However in certain scenes, the character will sort of twitch when she's walking (this is a cartoon by the way). It's most noticeable in the preview at the end where entire frames would twitch. Is it an encoding problem?
I opened GSpot and it said it uses Xvid. I opened Virtualdub's File Information screen and it said the AVI uses the ffvfw MPEG-4 codec. The video is 23.976 fps. I have ffdshow set to decode: XVID, DivX 3, DivX 4, and DivX 5. I have ffvfw set to decode: XVID, DIV3.
I'm making a DVD so I'm just wondering if these twitchy problems will transfer over when I'm converting with TMPGEnc Plus.![]()
Results 1 to 11 of 11
I can think of two possible causes.
1) The source could have been PAL, and someone converted to NTSC (23.976) by dropping 1 frame in five, instead of just slowing it down
2) The field order could be wrong. You would typically notice this on wide panning type scenes, or on scenes with a lot of motion.Impossible to see the future is. The Dark Side clouds everything... -
I'm pretty sure the source is NTSC since I've seen a DVD in stores of it. So I'm guessing it's a DVD rip. So if the field order is wrong, how can I fix it?
Most of the scenes are ok though, it's just most noticeable in the preview.
If the video is already encoded into DivX, or XviD, then you would have to re-encode, reversing the field order. If the source files are in MPEG format, you can use PULLDOWN.EXE to reverse the field order.
Twitchy playback can be caused by older xvid codecs,download the newest xvid codecs.
If your video is already in DivX format, the you'll have to re-encode. I don't know of an easy way to change field order for an AVI. Pick a small scene, with noticable glitches, and then re-encode using VirtualDub (assuming you want to keep it in DivX or XviD). There is a 'Field Swap' filter which should do the trick if your problem is indeed field order. Just encode a small piece and see if it resolves your issue.
If it does not, you might also give John's suggestion a try. The ffdshow and ffvfw can be poor substitues for the real thing. The codecs for this are freely available. Check the TOOLS section to the left.
When installing the DivX 5 codec, just make sure you answer NO, when prompted to install the GATOR piece. After your done with the install, you should also run Ad-Aware (http://lavasoft.element5.com/software/adaware/), It's freeware, used to clean out any spyware/adware on your PC. Quick painless, and probably something you need anyway
The DivX codec is completely free, with no spyware, and that is what I would suggest you re-encode with.Impossible to see the future is. The Dark Side clouds everything... -
So I'm re-encoding the XviD AVI with Virtualdub and using the Field Swap filter to output to a DivX AVI? Why DivX?
It didn't work. Maybe there's no way to change it? After applying the field swap filter, the resulted AVI has lots of jaggy lines, which is even worse. Thanks for the help though. I guess it's something the creator did that caused those glitches.
Hopefully, the next episode won't be like this.
I would agree. If the field swap was even worse after the fact, then the original creator has probably dropped frames someone while encoding. A destructive encode like that cannot be fixed since the original frames are gone.
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 10:36 -
Music sound playback is greater than word sound playback
By shknoll in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:09 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
How to fix "twitchy' or "jerky" .asf files.
By bbanderic in forum Video ConversionReplies: 2Last Post: 21st Sep 2007, 18:48 -
playback on tv
By andyluong99 in forum Newbie / General discussionsReplies: 1Last Post: 18th Jun 2007, 17:08
