i have some video i want to back up by putting them on data dvds would it be wise to use 4x? or should i stick with 1x?
plz reply to jackster1232002@yahoo.com
because i have dial up and its really really really slow. thank you -
Right. Love it how so many want something but won't make any effort towards receiving it. I have dial-up, too.
1x? 4x? How about 2x? If your disc and recorder support 4x writing, go for it. If you're worried about it, spend the extra time and write at 1x. -
if we reply to your email personally how does the masses get benefit from the solution.
if your concerned about it use 1x but i think 4x would work fine as well -
if you have a decent burning program, burner and the media's up for it, use 4x... if your not too sure about 1/any/all of the above... do it at 2x... should be fine
Data DVDs
By DeathStalker77 in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2011, 22:08 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Dvp5982 reading dvds as data files
By themow in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Mar 2008, 22:52 -
Old dvds data = disapeared. Anything I can do?
By 007craft in forum Off topicReplies: 5Last Post: 4th Oct 2007, 13:38 -
using iffy DVDs for data storage
By blacktooth in forum MediaReplies: 48Last Post: 2nd Jun 2007, 14:45
