i have some mpeg2 svcd files that im not sure if i should just convert the audio or would i get better results if i reencoded the mpeg2 at a lot higher bitrate look better?
Nope. You can almost never make your destination file look better than your source. The exception being if your source has a lot of noise/distortion and you manage to lessen it by applying filters.
it will not look better than what you have as a source file -- can't make a silk purse out of a sow's ear you know ..
There is a Doctor Who serial, Tomb Of The Cybermen, with a featurette that details how the restoration team made the DVD transfer look better than the original source material. Or rather, how they made the original source material look less appalling. Once you see how much work had to be done on this serial, you'll never want to ask how you can improve something again.
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 22:33 -
Encoding with higher resolution doesn't preserve quality.
By aznstriker92 in forum Video ConversionReplies: 50Last Post: 2nd Oct 2009, 14:38 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 05:37 -
Will the quality increase if the bitrate is higher after conversion?
By Choppa in forum Authoring (VCD/SVCD)Replies: 16Last Post: 3rd Jul 2007, 10:23
