i have a sony digital 8 camcorder. i've been trying to transfer video to my pc thru the supplied usb cable. i know i should use firewire. anyway, here's the real problem- the video that is captured is choppy, and the resolution is terrible. the supplied software, pixela, also allows me to take stills from the video. again, the resolution it terrible- the pictures are too dark, not crisp at all like when i watch it on my camcorder screen or even on the tv. will firewire solve this? or do i need to buy more stuff?
i need help- i'm a complete amature!
the firewire definately helped with the choppyness. now it looks smooth. the only problem is, the video on the screen is nowhere near as good as it is on my tv when i watch playback of the tape. the captured video is really dark and not nearly as detailed. any ideas?
Computer displays are usually much darker than television -- they use a much lower gamma setting. If your final output will be on a TV (via DVD) you probably don't have to worry about the brightness.Originally Posted by chez202
Also on the computer the resolution is much higher so you think the detail is lower than it should be but when its watched back on a tv then it will look normal.
AVS Video Converter 7.1 Quality Problems
By toulsonguk in forum Video ConversionReplies: 0Last Post: 1st Jul 2011, 13:28 -
Help please! Easycap DC60 no audio and bad quality video problems!
By thorn1414 in forum Capturing and VCRReplies: 2Last Post: 17th Oct 2010, 10:24 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Problems encoding a quality streamed video
By Berek Halfhand in forum Video Streaming DownloadingReplies: 7Last Post: 13th Feb 2009, 22:24 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
