Was given this mini dv camcorder, but no manual. Am I right in thinking that this records an ntsc signal even though it is the European model? If so I presume that after transfer to my pc I must set my encoder to ntsc. he unit has a menu function which allows ntsc playback on pal tv, but I don't think that affects the transfer signal does it?
If anyone has used this camcorder I would be grateful for any instructions on transfer and conversion to dvd.
I got the following from an old post on camcorderinfo.com (I believe the poster owns a TRV16E):
"There is no way of changing the system between NTSC and PAL since the CCDs are different (680K pixels for NTSC, 800K for PAL)."
If you have no luck here, you might want to try posing your question on this board:
http://www.camcorderinfo.com/bbs/forumdisplay.php?s=9c30f5e406d4e7caf427601c3946f390&forumid=6
Looking for a replacement of my Sony DCR-PC8
By rjonkers in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 5th Feb 2012, 16:06 -
Looking For Something Better Than a Sony Handycam DCR-DVD105
By PeripheralVisionaryX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 21st Jun 2011, 14:11 -
Sony DCR-PC108E Handycam
By ckbasak in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 13th Jan 2010, 13:57 -
Capturing from Sony DCR-TRV320E
By cirbic in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 2nd Dec 2008, 11:09 -
Sony Handycam - DCR-HC20E
By nzmikey in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 05:17
